bilico
June 27, 2019, 7:09pm
1
Hello
is there any way to apply noise to objects created in rhino 6?
to leave the objects that I make more realistic
it’s possible ?
thanks
bilico:
noise
Could you define noise with some pictures, models?
From the sound of it I think Grasshopper is the way to go.
Also give Galapagos a try.
bilico
June 27, 2019, 7:25pm
3
is there a noise plugin?
I wanted to deform geometry
I do not want to use displacement
you can (ab)use the smooth command. it depends on your geometry of course. works well if you have a few more vertices or cp`s. set it to something like 2 for a start and hit the button once or twice. it will start crumbling. maybe worth a try.
nathanletwory
(Nathan 'jesterKing' Letwory)
June 27, 2019, 8:11pm
5
Out of interest: what is wrong with displacement?
You can do object deformation with Grasshopper quite easliy. There are lots of demo with 4Dnoise
Tested and working.
[4DNoise]
You need to
Add the gha to the GH Components folder (/Users/**username**/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Grasshopper/Libraries)
Start Rhino
Start GH.
Find the components in Maths > Noise
[07]
4DNoiseExample.gh (13.1 KB) Definition also relies on @piac ’s Weaverbird components .
Hi @deja.vrbn ,
You could achieve this by checking if a new point has a certain minimum distance to all the previously created points and save it, only if the minimum distance criteria is met.
import perlin
sn = perlin.SimplexNoise()
pList = [ ]
for i in range(x):
for j in range(y):
for k in range(z):
perVal = sn.noise3(i * scaleX, j * scaleY, k * scaleZ)
if (perVal > lowerLim and perVal < upperLim):
I’m trying to simulate a stone wall.
In my definition in saltamosnte I find a problem at the end, when I want to make the “Patch” of the set of modified voronoi tiles.
If I go through the list using a slider, the patch is correctly formed, but when I apply a serious one the result is not what I expected.
Attached some images and the file in saltamosntes.
From already thank you very much!muro de piedra.gh (20.3 KB)
[p1] [p2]
