Thanks for looking !
The descriptions show and work for most things, When there are two (for left click and right click) of them one is overlapping the other and it’s unreadable. Any way to fix this.
Also at the bottom of the screen Grid Snap and the other buttons are on top of one another.
Please Help
Cheers, Brant
Please run SystemInfo in Rhino and copy/paste the results here.
Rhino 7 SR31 2023-6-15 (Rhino 7, 7.31.23166.15001, Git hash:master @ 850d276b2d59d7e51843939e4cf674b356bcd354)
License type: Evaluation, build 2023-06-15
License details: Cloud Zoo
Expires on: 2023-10-25
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 6-23-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.40
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2023
Driver Version: 31.0.15.3640
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.31.23166.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.31.23166.15001
That looks OK… I see you have two monitors attached - are they the same resolution? Do you have any display scaling activated? Does this still happen if only one monitor is attached?
So I got it to work with the second monitor. I had it at Settings> system> Scale and layout at 150% so I can read the text. With that off the display works properly. Is there any way to get it to work at 150%?
Are both monitors at the same resolution/scaling? I have two 4K monitors and I run 150% scaling - seems to be OK.
yes both are the same 150% now and the problem still exists.
OK, that’s all I can think of…
okay thanks for your help. Maybe someone else will have an idea.
