Rhino 8 UI strange/bogus tooltips & appearance
Hi, is there a way to:
  1. Suppress mouse hover tooltips (is this the correct term?) that repeat the word I’m already hovering over and mask the stuff below and to the right?
  2. Reduce those tooltips’ size. Too much pixel padding.
Animation14A
  1. If they exist, make those tooltips load faster. Rhino.Options.TabPanels.ToolTipDelayInMiliSeconds doesn’t seem to make a performance difference for me. It looks like the first time the mouse hovers over a “panel’s” buttons there’s a delay, then rolling over those buttons becomes fast until you move the mouse away and back.
Animation14B
SystemInfo
Rhino 8 SR4 2024-1-23 (Rhino 8, 8.4.24023.15001, Git hash:master @ e0f90d20c78f2125a0ec9cfffc9d9decbc052c01)
License type: Evaluation, build 2024-01-23
License details: Cloud Zoo
Expires on: 2024-03-04
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24023.15001
Possible to get some attention on this?
Thanks.
Here’s another example. Why is this tooltip so enormous? Top, left, bottom padding are already too big by apparent default, then right of the word “Column” I think we can all agree needs shrinking.
Hello- I don’t know how much control we have over tooltip size - if any. Here are some other Windows apps
Ok. So the tooltip size is a Windows thing? I wonder where I could find a setting to shrink those, because R8 looks way different than R7.
What about #2 above, the superfluous R8 tooltips that appear to repeat the word that I’m already reading?
V7:
V8:
V7:
V8:
V7: smaller and a contrasting color, black outline or drop shadow
V8: larger and same color as background, slightly darker gray outline
Gijs recently made a number of tooltip related bugs (including this one about size). We will be trying to address these very soon.
Sounds good. (Small and adjustable would be very welcome…)
Here’s another R8 tooltip size-related example for the record or McNeel’s use.
Floater tabs should show the tooltip indicating the tab name. Currently (Rhino 8, 8.5.24051.15001) they don’t:
Animation25A
SystemInfo-Rhino 8 SR5 2024-2-20
Rhino 8 SR5 2024-2-20 (Rhino 8, 8.5.24051.15001, Git hash:master @ 8ad7c99e58df0a8c09e572ba1ae2b52a6f429060)
License type: Evaluation, build 2024-02-20
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24051.15001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
