Rhino WIP 2017-Sep-26 is now available. Download Now.
New in this release:
Bug Fixes:
- Annotation:
- Annotation: Text: Deleting a whole text with Backspace key in Edit Text dialog leaves the first letter of the text on the viewport (RH-41343)
- BooleanDifference:
- BooleanUnion: Noisy overlap handled poorly (RH-23090)
- Cycles:
- Display:
- GCon: Losing continuity (RH-6337)
- GetObject: GetObject and single surfaces edge and face picking at the same time (RH-41490)
- Installer: Setting custom install location fails (RH-41358)
- Localization: A few strings are not localized in Licensing dialog on Windows (RH-41465)
- No Subsystem: control already loaded error when using multiple gridviews with custom cells and eto tabs (RH-41438)
- PluginManager: PlugInManager page does not display (RH-41540)
- RDK: Texture evaluation incorrect for leather bump texture (RH-41134)
- Rendering: Environment acts differently on Rhino Render, Rendered Display and Raytraced - which one is correct? (RH-39531)
- Rendering: Realtime SDK: View capture initial preview is wrong (RH-41324)
- SDK: RhinoCommon: Replace “Icons” folder with “Resources” folder in RhinoCommon plug-in template (RH-41536)
- Split: SrfSplit is fail in GH (RH-40879)
- SubD: Rhino SubD cleanup for Tuesday Sep 22 WIP Release (RH-41569)
- Surface-surface intersection:
- TextObject: Scriptable version does not work (RH-41442)
Download Now and report any problems in this forum.
