New in Rhino WIP 2017-July-25
Rhino WIP 2017-July-25 is now available. Download Now.
New in this release:
Crash bugs fixed:
  • File IO: Bad crash trying to open this file (RH-40028)
Bug:
  • Annotation: Alternate dimension tolerance is ignoring the linear resolution setting (RH-39954)
  • Annotation: Leader: Modal dialog box in the way of selection (RH-39133)
  • Annotation: Styles: Annotation page is blank (RH-40373)
  • Area: Slow for surface (RH-40368)
  • Block:
    • Copy paste modified block error (RH-39733)
    • Copy-Paste block instance to the same file and name conflict (RH-39689)
  • BlockEdit: Generates uncaught exception and fails (RH-40402)
  • DPI Aware: Arrow heads in dim styles, not DPI aware (RH-32501)
  • Display:
    • Bump map messes with mapping (RH-39688)
    • Curve is chunky when simple (RH-40239)
    • Diffuse alpha does not work correctly in rendered display (RH-38509)
    • Display issue - Far from origin - Prison Brussels (RH-40220)
  • File IO:
    • Choosing a specific file prevents the user from being able to select any file (RH-39979)
    • ImportLayout Check just one (RH-39894)
    • Rhino 6 freezes opening up its own file (RH-39618)
  • FilletEdge: Trim and join fails (RH-40313)
  • Insert: Dialog doesn’t have the thumbnail options (RH-39244)
  • Installer: Make Icons Work when we switch to RhinoCore.dll (RH-40278)
  • Localization: Untranslated command in German Rhino (RH-40114)
  • Paraboloid: Parabola3Pt (RH-39433)
  • PluginManager:
    • NuGet UI for Plug-in Manager (RH-40326)
    • RhinoCycles list as “Plug-ins that do not ship with Rhino” (RH-40415)
  • PointCloudSection: PointCloudContour cannot produce something useful (RH-39515)
  • Properties:
    • No Dimension Properties to Overrides in Properties Inspector (RH-39987)
    • Object properties sub-object selection pages are broken (RH-40435)
  • SDK:
    • Add Non-MFC classes to the Rhino SDK for extending the Options, Document Properties, Object Properties and Panels UI (RH-39644)
    • CRhinoObjectPropertiesPage::RunScript needs a CRhinoCommandContext& parameter (RH-39651)
  • SDK: GHPython: GhPython compiled components Hints issue (RH-40117)
  • SDK: Python: Implement SurfaceSphere (RH-39476)
  • SDK: RhinoCommon: Rhino.UI Assembly needs to be cleaned (RH-40444)
  • SDK: RhinoScript: AddPipe() fails (RH-40438)
  • ShowNotifications: ShowNotifications: Make a dash version that controls visibility (RH-39497)
  • Toolbar: Change macros and menus to suit new UntrimHole (RH-40052)
  • UntrimHoles: Combine with DeleteHoles (RH-38612)
  • ViewCaptureToFile: Transparent with vertex colors (RH-40207)
Feature:
  • EditPythonScript: Eto namespace and methods need to autocomplete in Python Editor (RH-40208)
  • Grasshopper: Referencing dots from point parameters. (RH-40379)
More Details.
Download Now and report any problems in this forum.
