Rhino WIP 2017-Oct-24 is now available. Download Now.
New in this release:
Bug Fixes:
- Annotation: Add case change buttons back to Text and Leader dialogs (RH-41912)
- Annotation: Hatch: Hatching Issues with custom PAT files (RH-41988)
- Annotation: Leader: Allow changes to Leaders, except for moving the arrow point, without breaking history (RH-41917)
- Annotation: Text:
- BlockEdit: Increases text size (RH-41698)
- BooleanSplit: Fails in V6 works in V5 (RH-41839)
- CopyHole: Does not work (RH-42016)
- Cycles:
- Display:
- Alpha channel isn’t clean in Rendered mode (RH-41895)
- Bounding box always on (RH-41813)
- Conduit is called twice for SC_PREDRAWOBJECTS (RH-41376)
- Locked layers using locked object color - should be layer color (RH-42024)
- No shadows when creating a layout detail with ortho projection + Rendered mode. (RH-41641)
- Rendered mode completely broken in VMWare 10 (RH-42051)
- Rendered mode default lighting broken (RH-41960)
- Skylight often looks grainy (RH-41756)
- ExtractConnectedmeshFaces: Not so many decimal places needed (RH-41880)
- File IO:
- Gumball: SubObject selection filter and Gumball (RH-41994)
- Help:
- IncrementalSave: File name not updated correctly (RH-41964)
- InsertKnot: Phantom control point after point insertion (RH-41690)
- Installer: License key and Zoo server information should be required values (RH-41412)
- Localization:
- MatchSrf: Surface disappears (RH-41791)
- No Subsystem:
- Options: Toolbars > Size and styles: Missing descriptions (RH-42053)
- Panels: Tools menu capitalization (RH-42131)
- PluginManager: Properties display glitch (RH-41978)
- PropertiesPage: Scrollbar missing in some Properties Pages (RH-41450)
- RDK:
- Rendering: Assigned environments in Rendering panel are not saved (RH-42086)
- Rendering: Materials:
- Rendering: Realtime SDK: View capture dialog should allow setting the number of passes (RH-41322)
- Rendering: Texture Mapping: Advanced texture preview only updates after selecting objects (RH-41876)
- SDK: Python: Typo in AddSubCrv help topic (RH-39892)
- SDK: RhinoCommon:
- SelVolumeObject: Leaves that selection object highlighted. (RH-42066)
- Selection: Curve points on hidden curves influence view (RH-41838)
- Settings: Don’t save CreaseSplitting setting (RH-41897)
- Snapshot: Snapshot UI doesn’t update with “older data” (RH-41905)
- Splash and About: EN Rhino 6 on TW Win10, template file names can’t display (RH-41821)
- SubD Editing: Add ON_SubD C++ SDK tool to easily extrude a subset of SubD faces (RH-41586)
- Subobject Selection: Crv Selection - Extrude (RH-41610)
- Sweep1:
- Textures: Menu tidy (RH-42132)
- Toolbar: Button text is cut off (RH-42054)
- UI Cleanup: Rendering Panel UI change (RH-42068)
- UntrimHoles: Add a built in alias (RH-41724)
- ViewCaptureToClipboard: View capture no longer works with Raytraced (RH-42007)
Usability Problem:
- SelU: Click on the control polygon (RH-29185)
Feature:
- Cycles: Two-Point perspective rendering not supported (RH-30150)
Download Now and report any problems in this forum.
