New in Rhino WIP 2017-Oct-3
Rhino WIP 2017-Oct-3 is now available. Download Now.
New in this release:
Bug Fixes:
  • Annotation: Add a control for Length Factor (RH-41429)
  • Annotation: Styles: Add a control for Length Factor (RH-41430)
  • ApplyDisplacement: Crash on open (RH-41512)
  • BooleanDifference: Grasshopper component slow (RH-41335)
  • BooleanUnion:
    • Booleans with overlapping faces should merge the overlap region (RH-41545)
    • Problem after nudge (RH-8484)
  • Core bugs: Invalid component_name parameter (RH-41150)
  • Crash: Copy to clipboard crash in plug-in manager (RH-41620)
  • Cycles:
    • Device selection checkbox needs two clicks to toggle (RH-41551)
    • Environment textures sometimes show up as pink (RH-41683)
    • Ground plane is always z=0 (RH-41604)
    • Have good and fluid fallback (OpenGL) for Raytraced on slower hardware (RH-33781)
    • Incorrectly rebuilds BVH tree when the view changes (RH-41651)
    • Settings file with incorrect SelectedDeviceStr can cause crash (RH-41492)
    • Skylighting is dim/low contrast (RH-41508)
    • Sun through glass problem (RH-41504)
    • Turning on the ground plane doesn’t work (RH-41650)
    • Whites and colors are totally different between OpenGL, Raytraced and Rhino Render… who’s right? (RH-37762)
  • Display:
    • ClearAllObjectDisplayModes (RH-41530)
    • Curves aren’t highlighting in selection menus (RH-41661)
    • Downgrade skylight shadow on high-dpi displays with Intel GPU (RH-41518)
    • Hidden lines in Technical display mode look bad (RH-41556)
    • Objects lighter than the background in OpenGL (RH-41603)
    • Shaded mode doesn’t always show mesh edges (RH-41510)
    • Shaded preview for revolve doesn’t look right (RH-41182)
    • Shadows are incorrect for blocks containing transparent materials (RH-41301)
    • Shadows messy in Artistic (RH-40944)
    • Snapshot thumbnails aren’t showing materials correctly (RH-41499)
    • xyz on world axis icon can not display on Chinese Windows (RH-35571)
  • File IO:
    • File not recognized by Word, OpenOffice (RH-30081)
    • SKP export duplicates layer material (RH-41456)
    • SKP import makes too many nested layers (RH-41646)
  • Help: Generate online SDK documentation for C++ SDK (RH-33501)
  • Line: Bothsides + tangent from a point doesn’t accept distance input (RH-41615)
  • Localization: Untranslated dimension properties in German WIP (RH-41062)
  • Make2D: Piano missing lines (RH-41326)
  • MatchSrf: On Extrusion fails with History (RH-41583)
  • Mesh2: Option to output quads when possible (RH-41606)
  • NamedView: Thumbnail image is wrong (RH-41596)
  • Options: Add “Restore Defaults” button to Options->View page (RH-41549)
  • Project: Makes too many points (RH-41633)
  • RDK:
    • Custom render meshes always use object’s texture mapping (RH-41173)
    • Raytraced doesn’t show the custom material set by the custom render mesh provider (RH-41609)
  • Rendering: Force aspect ratio is not implemented for Snapshot/Named View (RH-41608)
  • Rendering: Materials: Opening skp file with 3 objects all referencing the same material results in 2 materials in Rhino (RH-41506)
  • Rendering: Texture Mapping: Incorrect if edge softening is on (RH-41496)
  • SDK:
    • DrawAnnotation override needed (RH-41676)
    • Rhino crashes when changing texture mapping if attached to RhinoDoc.TextureMappingEvent (RH-41505)
  • SDK: RhinoCommon:
    • Crash in ON_Object_Delete when shutting down Rhino (RH-41648)
    • DisplayPipelineAttributes should provide access to FillMode (RH-41552)
    • DisplayPipelineAttributes.FillMode always returns FrameBufferFillMode.DefaultColor. (RH-41684)
    • Expose CurvatureAnalysisSettings to RhinoCommon (RH-41462)
    • GroupTable.FindName fails (RH-41673)
    • RhinoCommon plug-in wizard creates incorrect to project icon (RH-41539)
  • Select: Serious picking problems (RH-41513)
  • Snapshot:
    • Snapshots - checkbox per category (RH-39084)
    • Snapshots - right click on property deselects all other properties (RH-39083)
  • SplitRefit: Failure example (RH-41270)
  • SubD:
    • Fix bugs in persistent subobject select (RH-41489)
    • UNDO Gumball SubD extrude - not clearing dynamic display. (RH-41679)
  • ViewCaptureToClipboard: ViewCaptureTo* command should populate DisplayPipelineAttributes with correct fill mode (RH-41554)
  • ViewCaptureToFile: Transparent background option doesn’t propagate to ViewCaptureToFile dialog (RH-41478)
  • Zoo: CloudZoo Client: Can’t easily change from one team to another (RH-41590)
Enhancement:
  • Cycles: Raytraced viewport - allow scaled rendering (RH-38468)
  • SubCrv: Add current curve length indication to the SubCrv command (RH-41616)
Download Now and report any problems in this forum.
