Rhino WIP 2017-Oct-3 is now available. Download Now.
New in this release:
** New Features:**
- Grasshopper: Grasshopper wire relays (RH-41853)
- Lights: ON_Light “Solo” option (RH-36044)
- PackageManager: New TestPackageManager command (RH-40813)
Bug Fixes:
- Annotation:
- Annotation: Leader: Does not accept an empty string when edited (RH-41820)
- ApplyDisplacement: Kicks off a refresh at odd times (RH-41644)
- Arctic display: Arctic does not gamma correct output (or input) (RH-41717)
- BooleanDifference: Boolean fails with tangent intersection (RH-11160)
- BooleanUnion: Boolean failure (RH-4497)
- Build Process:
- Cycles:
- Display:
- Black viewports in VMWare Workstation running win 10 guest (RH-40778)
- Don’t drop out of dynamic mode until the mouse button is released (RH-41805)
- Grenoble Model Does Not Display (RH-41143)
- Ground plane material isn’t being shown in Rendered mode (RH-41183)
- Gumball axes messy (RH-33050)
- Heavy texture loading stalls Rhino (RH-41357)
- OpenGL skylighting shadow is not dark enough (RH-41602)
- Shadows from lights and sun are pitch black in Rendered mode. (RH-41535)
- Skylight causes washed out effect (RH-41560)
- Wireframe is not continuous or clean (RH-32449)
- ExtendSrf: Failure situation (RH-38876)
- File IO:
- GumballTransform: Extrude on a mesh face problem (RH-41528)
- Help:
- LibrariesTab: Panel Help button does not work (RH-41806)
- Licensing and Validation:
- Localization: Typo in toolbar file. (RH-41829)
- Make2D: Dimension locations off (RH-41659)
- MeshTools Plug-in: All “CollapseMesh*” commands are Unknown (RH-41799)
- NamedCPlane: Panel Help button does not work (RH-41800)
- NamedPosition: Panel Help button does not work (RH-41802)
- NamedView: Panel Help button does not work (RH-41801)
- NonmanifoldMerge: Remove duplicate faces (RH-40308)
- PluginManager: PlugInManager displaying test commands (RH-41873)
- Rendering: Materials:
- Rendering: Texture Mapping: Cylindrical mapping shows edge artifact in Rendered mode (RH-41597)
- SDK:
- SDK: RhinoCommon:
- SDK: RhinoScript:
- Selection: Mesh sub-objects in shaded mode problem (RH-41565)
- Snapshot: Could use the ability to save focal blur view settings (RH-41502)
- ViewCaptureToClipboard: ViewCaptureToClipboard is broken (RH-41749)
Usability Problem:
- Toolbar: Extend to Boundary Macro (RH-40069)
Download Now and report any problems in this forum.
