Rhino WIP 2017-Aug-29 is now available. Download Now.
New in this release:
Feature:
- Grasshopper: Component support for task based solving (RH-40882)
Crash:
Cosmetics:
- Layout: LayoutProperties command’s dialog should be titled “Layout Properties” rather than “Modify Layout” (RH-38339)
Bug:
- Annotation:
- Avoid writing rtf strings to dimension user text in SaveAs V5 (RH-40833)
- Remove “More Properties” top expander from Dimension properties (RH-40559)
- Selecting two dimensions at once causes some Dim properties to go to zero (RH-40749)
- Set distance scale for paper space dimensions referencing model space distances when saving to v5 (RH-40835)
- Annotation: Leader: When reading V5 file with leader text not horizontal (RH-40771)
- Annotation: Styles:
- Annotation: Text: Remove annotation text case changing buttons (RH-40957)
- Block:
- BlockEdit: Copy paste fails (RH-40576)
- ClippingPlane: Keep the current setting (RH-40570)
- CopyLinkedBlockDefinition: Block with objects set to “by parent” Problem (RH-39573)
- Cycles:
- DPI Aware: Some text in Button Editor is clipped (RH-40580)
- Display:
- Doesn’t work correctly when shadows are involved (RH-40789)
- Edge reduction incorrectly overrides selection candidate (RH-38791)
- Locked layers using locked object color - should be layer color (RH-40850)
- Mesh disappears when blocked (RH-40675)
- Monitor power save mode makes existing curves disappear in viewports (RH-40911)
- Objects on locked layers in a instance definition do not draw (RH-41028)
- Play, Pause and Lock button not rendering in correct place when inside a detail (RH-40932)
- Points show through clipping plane (RH-40728)
- Render Preview does not correctly display assigned material (RH-40445)
- Render display mode not showing materials correctly (RH-39624)
- Rendered mode produces display artifacts with transformations (RH-40788)
- Sub-objects with transparency maps don’t show objects behind them consistently in Rendered mode (RH-40873)
- SubD doesn’t show selection highlights for sub-objects (RH-40862)
- Distribute: Add Z axis option in distribute command; bugs in keyboard entry (RH-39798)
- Documentation: Document how to switch to NuGet packages in RhinoCommon / Grasshopper projects (RH-39033)
- Drag:
- EditPtOn: Edit points cannot stay on (RH-40953)
- Export: Text wrap width narrows when opened in AutoCAD 2017/2018 (RH-40622)
- File IO: Curve skipped in DXF import in V4/5/6, but OK in Acad 2012 and Rhino V3 (RH-40935)
- Grasshopper:
- Icons: Ngon commands need icons and inclusion in the Mesh Tools toolbar (RH-40674)
- Insert:
- Make2D: Result displaced (RH-40048)
- MatchSrf:
- No Subsystem:
- OSnap:Mid: Snap to edges as to the duped edges (RH-40388)
- Offset: Nested Length command doesn’t clear dynamic drawing (RH-40857)
- OpenNURBS: :WriteBool() (RH-40941)
- Options: Wrong default for color list path (RH-40952)
- Panels: Menu wanders off the current monitor (RH-37480)
- PluginManager: Filter remembers last value, but doesn’t filter. Then crashes. (RH-40861)
- PluginWizards: Update VS for Mac plugin to select correct DerivedData folder if more than one exist (RH-40922)
- Project: Record history very slow update (RH-40721)
- RDK:
- ReduceMesh:
- Rendering: :Read() read bug - serious issue (RH-40908)
- Rendering: Materials:
- Rendering: Texture Mapping: Properties numbers incorrect (RH-40585)
- SDK:
- SDK: RhinoCommon: API Documentation for RhinoDoc.BeginOpenDocument Event should note that it will get fired by a paste operation (RH-37575)
- SelWindow: Window Selection Bug (RH-15147)
- SimplifyCrv:
- SubD: SubObject selection highlight on SubD objects not working (RH-40851)
- Update System: License and update traffic jam (RH-40362)
Usability Problem:
- Toolbar: Extend to Boundary Macro (RH-40033)
Enhancement:
- Help: Document Autosave action (RH-40947)
- Panels: Panel flickering when rotating viewport (RH-40897)
- Rendering: Materials: While dragging and dropping switch materials in the material editor (RH-37672)
Download Now and report any problems in this forum.
