Rhino WIP 2017-Jun-13 is now available. Download Now.
New in this release:
Bug:
- Annotation: Hatch: Keep the pattern on mirror (RH-3518)
- Annotation: Text:
- CopyLinkedBlockDefinition: UI change (RH-37057)
- Cycles:
- Display:
- Black viewports in the new WIP (RH-37027)
- Block preview not working (RH-38692)
- Blocks are drawn with wrong color (RH-39741)
- Disappears if layer is locked (RH-39580)
- EnableRedraw False/True call in RhinoScript slows down display (RH-39520)
- Issue with Block display on Layout (RH-39487)
- Objects in blocks display when their layer is off (RH-39590)
- Render Display Mode, Rhino stops working (RH-39272)
- EditPythonScript: fix import statements in Python command template (RH-39685)
- File IO:
- Gumball: Can’t enter values on Gumball (RH-38709)
- Make2D: Colons in front of layer names (RH-39355)
- Picture: Re-uses an old image (RH-39572)
- PluginManager: Add “Open containing folder” button to plug-in properties page (RH-39097)
- PluginWizards: Path error when Rhino is not installed (RH-39662)
- Print: Switch layout crash (RH-39550)
- Properties: Attribute User Text > “New” button has to be clicked twice for it to work (RH-39514)
- SDK: RhinoCommon:
- Select: No ‘selection candidate’ highlight on colored point clouds (RH-38341)
Download Now and report any problems in this forum.strong text
