Rhino WIP 2017-May-9 is now available. Download Now.
New in this release:
Enhancement:
- ExtractPt: Add option to create point cloud with extracted points (RH-38761)
Bug Fixes:
- Annotation:
- Annotation: DimLinear:
- Annotation: Dot: Text size breaks alignment (RH-39165)
- Annotation: Leader: Cannot edit leader fraction (RH-39127)
- Cycles:
- Display:
- Clipping Planes not working on Point Clouds (RH-39202)
- Crash on rotate (RH-39224)
- Polysurface display doesn’t update properly with GPU tessellation on (RH-39201)
- Produces white output (RH-39005)
- Rendered mode materials, lights and shadows seem unnecessarily slow (RH-39149)
- Skylight locks up computer (RH-39163)
- Speed with selected control points is slow (RH-39109)
- View degradation remains even after releasing the mouse button. (RH-39235)
- Display: OpenGL 3.3: Black viewport in rendered mode on Mac (RH-38919)
- Drag: Crash dragging meshes with Gumball (RH-39197)
- File IO: Multiline text missing from dwg import (RH-39132)
- Grasshopper: “Component ID Conflict” dialog hides content and buttons (RH-37618)
- Help: Change links from Rhino to Help (RH-39047)
- Licensing and Validation: Confusing Validation verbiage (RH-39203)
- Make2D: Missing silhouette (RH-39029)
- Named Position: Avoid named position duplicates (RH-39023)
- Options: Rhino crashes when double-clicking on an options value (RH-39193)
- PluginWizards: Create new Grasshopper wizard for VS2015 and VS2017 (RH-39066)
- PointDeviation: Label tune up (RH-39183)
- SDK:
- SDK: RhinoScript: :FindInstance" needs to support multiple contents in V6. (RH-25770)
- Snapshot: Camera clips between snapshots in certain Display Modes (RH-38965)
- Splash and About:
- SquishInfo: No longer works after MFC Free SDK changes (RH-39125)
- Toolbar: V6 icon for WIP update (RH-39167)
- TweenSurfaces: Incorrect result (RH-38929)
- UI Cleanup:
- ViewCaptureToFile: Larger than monitor view captures don’t work with Ground Plane enabled (RH-38260)
New Features:
Cycles: Should support clipping planes (RH-29665)
Eto: Add visible gutter on splitter when mouse hovers over it (RH-38881)
Snapshot: Snapshots - Import snapshots from other files (RH-38308)
UI Cleanup: Add document object selection menu to user text keys (RH-38796)
Download Now and report any problems in this forum.strong text
