New in Rhino WIP 2017-May-23
Rhino WIP 2017-May-23 is now available. Download Now.
New in this release:
Bug:
  • Annotation: Text: add font related read only properties to native rtf parser and expose them in RhinoCommon (RH-39249)
  • ApplyDisplacement: Displacement broken (RH-39334)
  • ApplyThickness: Broken in rendered display (RH-39335)
  • BlendSrf: Handle points out of control (RH-39212)
  • Cycles: Application settings UI for Cycles/Raytraced (RH-38447)
  • Display:
    • Bump doesn’t change in Rendered mode when changed in material (RH-39424)
    • CurvePiping broken in Rendered Display (RH-39333)
    • Reflection polish causes Rendered mode to display metal materials as black (RH-38255)
    • Scaled view captures are all white (RH-39427)
    • Shaded mode in VMWare looks wrong on a box (RH-39162)
    • Should put display into dynamic mode (RH-39261)
    • Textures remain in Rendered mode after being removed from a material (RH-38851)
  • ExportOptions: Fails to open the file (RH-39418)
  • File IO: Fails if ngons option is checked. (RH-38121)
  • Grasshopper: Cluster warning? (RH-34465)
  • Gumball: In Trim command redraw the views to remove residual gumball (RH-38155)
  • Make2D: Consistent output placement in View option (RH-37895)
  • PlanarSrf: Should orient the plane so that outer boundaries are not reversed from the input (RH-39310)
  • PointDeviation: Move panel to the front (RH-39304)
  • Ribbon: Suggestion by Armido Cremaschi (RH-3475)
  • SDK: Python: Change Rhino Python Editor Help menu to point to developer.rhino3d.com instead of windows help file (RH-32185)
  • Snapshot:
    • Saving Snapshots takes long to save (RH-39311)
    • Snapshot - SDK needs documentation (RH-39359)
    • Unexpected material behavior (RH-38803)
  • Space Ball:SpaceMouse: Modify 3dxRhino plug-in for public SDK usage (RH-39434)
  • UVEditor: Object black instead of showing texture while open in UVEditor (RH-33419)
Feature:
  • Autocomplete: Scroll inside the command autocomplete list (RH-39131)
  • Snapshot: New Slideshow option (RH-38310)
More Details.
Download Now and report any problems in this forum.strong text
The “More Details.” link in the post above points to the report for changes from May 9th to May 16th and is an exact copy of the report for the previous WIP.
I propose the following to reflect changes after that that are in the current public WIP:
More Details.
@wim you’re better at parsing our version numbers than many of our developers :slight_smile: I’ve updated the link in the original post to be correct. Thanks for the head’s up!
