New in Rhino WIP 2017-Jun-6
Rhino WIP 2017-Jun-6 is now available. Download Now.
New in this release:
Enhancement:
  • SDK: RhinoCommon: Rectangle3d.CreateFromPolyline could be a lot better. (RH-39529)
  • UI Cleanup: Add Context Menus for Filtering By Selections (RH-39482)
Bug Fixes:
  • Annotation:
    • When text using different styles are selected, allow font overrides (RH-37880)
    • With no or all text selected, selecting a font from the dropdown should change all text to that font (RH-39463)
  • Annotation: Styles: GridView control should not allow column re-ordering (RH-38189)
  • Annotation: Text:
    • Editing Multiple Text Objects - Changes String To “Varies” (RH-39474)
  • Catenary: Point count when Output=Polyline incorrect (RH-39532)
  • ClippingPlane: Cap/fills seem to be intermittent depending on the visibility of layers and or objects (RH-39102)
  • Cycles:
    • Clipping plane doesn’t update when object is moved (RH-39246)
    • For Rhino renders just gray (RH-39564)
    • Raytraced display - clipping plane doesn’t update (RH-39604)
    • Raytraced stopped working after Cycles For Rhino was fixed. (RH-39589)
    • Rotating the Environment bitmap doesn’t make a difference (RH-39214)
  • Decals: Rendered view goes black after a certain number of decals are applied/created (RH-39028)
  • Display:
    • Curve thickness float or int - SDK needs to choose one or the other (RH-39518)
    • Custom lighting fails (RH-38842)
    • First frame draws black material when dragging from Material Library (RH-39001)
    • Rendered display goes dark after dragging material to it (RH-39196)
    • Switching display modes incorrectly triggers profile save (RH-39477)
    • TestMaxSpeed and Ambient Occlusion (RH-39386)
  • ExtendSrf:
    • Extend in negative value fails (RH-39469)
    • Keep the original as an extension (RH-39238)
  • Grasshopper:
    • Custom Preview component doesn’t bake geometry (RH-38782)
    • Mono.Cecil fails to parse GHA assemblies. (RH-39608)
    • Mono.Cecil includes (RH-39607)
    • Parabola thru Points (RH-39594)
  • Localization: “Restore defaults” selects a font different from the detected one (RH-38178)
  • Make2D: Make Layer Name scrollable field to accommodate long names (RH-39537)
  • OffsetSrf: Creates bad object in v6 but not v5 (RH-39567)
  • Options: RH-38178 fix crashes on Mac (RH-39627)
  • Ortho: Rectangle, Ellipse and ortho interaction (RH-1361)
  • Panels: Attribute User Text icon (RH-39360)
  • Print:
    • Curves on different layouts appear in the print preview (RH-39475)
    • File name on print won’t shift to bottom (RH-39337)
  • Rectangle: No preview on vertical rectangle (RH-39571)
  • Rendering: Icon for Focal Blur View Properties Page tab (RH-39551)
  • SDK: GHPython: Crash in V6, OK in 5 (RH-39044)
  • SDK: RhinoCommon:
    • Need Enum for LoadPlugin for GetFileNameMode (RH-39499)
    • Point4d.Transform missing. (RH-36479)
    • Polyline to Rectangle3D Bug (RH-37904)
  • Snapshot:
  • TextObject: Huge dialog width (RH-39480)
  • Toolbar: Panel macros consistency (RH-39279)
  • TweenSurfaces: Failure (RH-38928)
Usability Problem:
  • Annotation: DimLinear: DIM Style Text Alignment - Add “Text UNDER Dim Line Option” (RH-35466)
Feature:
  • Build Process: Create public openNURBS builds (RH-25601)
More Details.
Download Now and report any problems in this forum.strong text
The first time I used Octane for Rhino6 it worked just fine. Today Rhino 6 won’t open. It gives me an exception error related directly to Octane.
What should I do about that?
Thanks
eric
@Eric_Clough start Rhino WIP in Safe Mode and disable the Octane plug-in, then contact Octane regarding the problem. They’ll probably need to release a new plug-in.
Thanks Brian,
Rhino 6 is working now. Octane is not but if I save as Rhino 5 I can use Octane there so all is well.
cheers
@Eric_Clough, what did the error dialog say?
Hi Steve …
With a completely fresh install of both Rhino 6 and Octane for R6 it works the first time and the next time I get the first message below. Rhino won’t start.
After another install of Octane I get the second message … Rhino works but Octane doesn’t
Baffled.
Eric
Thanks; I was curious to see if there is something in those messages that were related to the core Rhino product. I’m not seeing anything that would help me fix any problem in Rhino so we’ll have to see what the Octane folks figure out.
More info …
If I reinstall Octane R6 each time after I have used it then Rhino 6 opens and Octane works. But Octane has to be installed each time before the next Rhino 6 use.
Thanks Steve
ok, new place for focal blur setting.
but it also doesn’t seem to work anymore.
whatever settings I try - no effect :joy:
just me?
Just wait for the upcoming wip, focal blur should work, per view.
OK, but now THIS.
