New computer, can't launch V8
When I launch Rhino V8 (fresh install) I see this. I click “Login….” and then nothing happens. Rhino.exe also drops off the task manager. Any hints?
We’ve seen this a few times since the last Windows update. Repairing the C++ redistributables resolves it.
The repair option can done with the following:
  1. Go to Control Panel > Programs > Programs and Features.
  2. Right-click Microsoft Visual C++ Redistributable and choose Repair.
  • Microsoft Visual C++ 2015-2022 Redistributable (x86) ← do this first
  • Microsoft Visual C++ 2015-2022 Redistributable (x64) ← you will now be prompted to reboot.
Let us know if this it doesn’t resolve your issue.
Thanks @Japhy but that didn’t help.
Another one that can do this is video driver and setup, but i still suspect the runtime.
We should also check if you can run in a different Microsoft runtime. Go to the rhino shortcut and add this flag.. /netfx Then run the shortcut
GPU settings are good.
/netfx gives me the sad rhino (I submitted the report)
Not seeing the error report yet.
Is there a Rhino entry in the reliability monitor?
Lets repair your runtimes again.. the 8.0.x might be a different version
yes, there are Rhino entries in the Reliability monitor. Here is one:
Source
Rhino 8
Summary
Stopped working
Date
‎3/‎12/‎2026 12:08 PM
Status
Report sent
Description
Faulting Application Path: C:\Program Files\Rhino 8\System\Rhino.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: Rhino.exe
Application Version: 8.29.26063.11001
Application Timestamp: 69a8859c
Fault Module Name: coreclr.dll
Fault Module Version: 8.0.1425.11118
Fault Module Timestamp: 67ac24a4
Exception Code: c0000005
Exception Offset: 00000000001894ff
OS Version: 10.0.26200.2.0.0.768.101
Locale ID: 1033
Additional Information 1: cc80
Additional Information 2: cc8024ac7ce6e92e2381b45058d7a5f6
Additional Information 3: 04d0
Additional Information 4: 04d0f6487843782a458d8fe393c353c4
Extra information about the problem
Bucket ID: 451a98bf87633973f050c14fec1ff469 (1175652051751793769)
And another one, in case it’s helpful:
Source
Rhino 8
Summary
Stopped working
Date
‎3/‎12/‎2026 7:08 PM
Status
Report sent
Description
Problem signature
Locale ID: 1033
Updated per above, double checked Nvidia, but still crashing (submitted a few of the crash dumps)
