I’ve started seeing a consistent problem with Rhino 8 on Windows.
When the user launches Rhino, the program opens, displays the splash screen and starts to display the main window, then completely disappears.
Re-installing Rhino, restarting or updating graphics drivers had no effect.
Even Rhino in safe mode displayed errors about the plugins (there are no third party plugins).
The only fix has been to repair the 2015-2022 x64 runtime.
Rhino will continue working for several days and then randomly start exhibiting the same problem.
I’ve seen this issue on personal and institutional computers, often with the latest C++ runtime installed, but not always.
Has anyone else seen this issue and determined the cause?
theoutside
(Kyle Houchens)
October 23, 2025, 6:58pm
2
yes- we have seen this before- you need to repair both the x64 and the x86 runtimes.
see this thread.
we have seen a few of these lately, the fix is to go to add remove programs in windows.
then repair these two components. (shown in image below)
do the x86 1st as it does not need a restart, then do the x64 and restart.
rhino should start up when the restart is complete.
[image]
I will try following your instructions exactly and see how it goes. I’ve not been repairing the x86 version.
Have you had the problem reoccur on the same computer?
theoutside
(Kyle Houchens)
October 23, 2025, 8:11pm
4
I have not seen it recur, but repairing one and not the other may be important.
we always repair both, so I am guessing in lieu of actual testing.
It may be worth grabbing the latest windows update as one of the recent past updates is what broke this. Ideally the latest update will fix it.
I’ll follow your advice and come back later to report.
theoutside
(Kyle Houchens)
October 23, 2025, 8:51pm
6
please do-
if you get stuck please call us at 206-545-6877
Replying to myself in case anyone happens upon this post.
I discovered the source of the issue was a print driver from Ricoh overwriting one of the VC++ runtime files. I found a newer version of the driver from the vendor and the problem hasn’t returned. I have 20 computers with this printer and none of them are seeing the issue after the driver was updated.
Also, note that in addition to Rhino, Adobe Premiere would fail to open while this problem was present.
