Hi!
I am trying to sweep around 1 rail a lot of curbs, that came from Contours around a brep.
I don’t know why, it is crazy what i have.
First, i join a screenshot, the idea is that i would like to sweep each curve, around each little circle. Maybe it is impossible?
In the next post, i will join the grasshopper file with internalized data.
Thanks so much!
This is the Grasshopper file.
Thanks so much!
26FevGHokSweep1Rail.gh (19.0 KB)
Third thread on this subject in two days!!! You’re getting way out of your depth when you don’t understand List Item yet:
P.S. Are you really expecting something like this? What’s the point? And yeah, I see that many are missing. Pursuing this further would be a waste of time for both of us.
Hi!
Yes, i would like something like this, with all the curves, every 2 mm…
But it seems impossible
Thanks so much
Are you trying to visualize an extruded 3d print?
Hi!
Thanks so much! What i am trying to do, is to find the way to sweep all the little circles of 0.4 mm of diameter, around each curves that come from the section of the ellipsoidal Brep, but, this, only in one manipulation, in order, after, to substract all of those polysurfaces created, that have 0.4 mm diameter, from the initial Brep.
Hi!
Thanks so much for the answer.
Well, i made those curves, but, what i would like to do, is, to sweep around one of each of those curves, a circle that has 0.4 mm of diameter.
I don’t know if there is a way in Grasshopper to make this manipulation?
I know how to do this in Rhino, but, in this case, i have to do the sweep, one by one, for the 69 curves i have here.
So, if there is a way to do this in Grasshopper, it would take less time, but i don’t know how it would be posssible?
Thanks so much
In red, this is what i would like to have, but not using Rhino, but Grasshopper, sweep around each curve, a circle that have 0.4 mm of diameter, from the section curves that come from the ellipsoidal shape we created in Grasshopper!
Use Pipe.
Hi!
Thanks so much! I will try it!
