hi, i have an issue with sweeping a shape over a non planar curve.
To start with, within the curve the curve dont have a unified direction ( tried to offset the rail curve to try and see if the sweep 2 might end with better result). Though not 100% convinced this is the issue, but when sweeping i cant seem to get to a satisfying result whilst having a closed curve as railing.
Could please anyone help me figure this out? I’ve tried many things to fix it up but can’t seem to get it.
Q1A.gh (23.2 KB)
Thank you for answering. I dont have access to the plugin you’re using (didnt find it on food4rhino). Although I was hoping to see where I messed up in my definition since a surface would make a cleaner section than a mesh (usually does anyways).
I downloaded it from here for those interested.
I still think that the curve irregularity (Most probably the variety of directions) messes the sweep up.
Isnt there any way to make a proper sweep in this context?
