Hello all,
I’m trying to achieve a model to use in a FEM program for a thermal simulation.
The model should consist of two closed geometries:
- the pattern offset or thickened by 8 mm;
- its negative cast adhering to both sides of the offset pattern.
Among the tries that I carried out until now, the most common error I noticed is that when I operate the component Mesh Difference between a scaled-down bounding box and the mesh offset with WB Mesh Thicken, 1) only one of the two surfaces of the mesh is used to generate a negative solid 2) this happens only when the scaled bounding box is below 0.30 (ca) as a scaling factor. My aim is instead, to have a solid negative filling adhering to both surfaces of the mesh + in a bigger bounding box (around 0.90/80 as a scaling factor). For the sake of the FEM analysis is important to have closed solids to be then converted into meshes.
Another aspect I would like to correct is the orientation of the offset/thicken mesh, is there a way to align its outer edges to the surface of the bounding box while still having a closed mesh?
Do you have any tips on how to work around this problem? Many thanks!
NegativeCast.gh (1.5 MB)
