Close Complex Open Mesh for 3D Print
I need to boolean difference a mesh and then print it, but MeshBooleanDifference doesn’t work because it is an open mesh. I’ve tried remeshing, filling the holes, and converting to subd, but nothing has worked. Does anyone know how I can make this a closed mesh?
columnzoom
column.3dm (5.2 MB)
If possible you must try shrinkwrap in Rhino 8 WIP
How did you manage to have such an awful mesh ?
Here a mesh that was healed with Dendro in Grasshopper.
I think you mesh has many problem, it is very far from the origin. And perhaps the scale. So I put the center near the origin ans made a 1000 scale.
With Dendro just use the mesh to volume component with a good voxel size. I choose 1 for the scaled mesh. It is more fast than Shrinkwrap!
column LD).3dm (8.9 MB)
Thanks so much, this worked! :))))
video to watch here-
