I opened a file in Rhino which was created in Archicad, then saved as a Rhino file. Many of the objects were block instances, but I was able to explode them into layers. I can change the color of the objects in shaded mode, but when I change the material in rendered mode, it does not show up. How do I fix this?
Hi Elena -
It’d be better if you could attach a small sample file with your question so that we don’t have to guess where you are getting stuck. When you change the color of the layer, you will see that change in shaded mode. To see things happening in rendered mode, you will need to apply a material to either a layer or an object. If that’s what you are doing, and in addition to providing a small file, please run the Rhino SystemInfo
command and copy-paste the result here.
The file came with materials already applied from Archicad, and when I try to change the material to one from the material library, it does not change/show up different in rendered. I’ve included a sample file with an object from the file I’m using. In this file, even though I’ve applied a lavender paint material to the object, in rendered it still shows up as green (like it was when I first opened it).
Sample.3dm (378.8 KB)
System Info:
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Educational, build 2023-06-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [68% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 3-16-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.90
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-29-2023
Driver Version: 31.0.15.2890
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
