Need help adding some coating surface perfectly fitting on structure
Hello all,
Please see the image with description below and I also added the model.
demo-surfacing.3dm (1.9 MB)
and how did you imagine fitting the surface to both brown and blue beams simultaneously when they deviate this much?
Hi Gijs,
I could fix it and remodel whole structure normal to the ground. But this is a ship structure and these members are actually skewed. And, thus, I wonder if I could make a surface like ships deck( cambering at middle)
Okay, so you want the surface to follow the brown beams and make cutouts where they intersect with the blue beams, do I understand that correctly?
