patch.3dm (167.0 KB)
Hi people,
I often have this issue where I need to create a surface referencing edge A and Edge B but the surface must perfectly touch C,
Could you give me some ideas on how to do this?
thanks in advance!
Hi people,
thanks in advance!
See Boat hulls with smoothly curve stems - how to model for several approaches.
you have some very narrow surface spans - fix them
(have not done this - just to fast / roughly outline the workflow below)
use _gcon and _edgeContinuity to check the surrounding continuities.
fix them as well.
now the questioned patch:
build a first surface (sweep2, or edgeSrf + _matchSrf) - green
make a copy of this surface.
_Split it by isocurve (shrink)
_splitEdge
_sweep1
_matchSurface with onSurface, Pull option.
trim the original surfaces
check this video for more details:
nice, I am already familiar with sky video series, and as I told David, the model is solved but my question remains if there could be a workflow to achieve this “surface match”
so you mean something like this ?
did not fiddle to the final 0.001…
but the only manual workflow I can imagine:
build a nice initial surface - or rebuild the one you have - less CVs, the better. Maybe start with a singleSpan - if you can not reach the desired continuity / conditions, _inserKnots
_divide the edge C, to get something like 100-500 sample points
use
_pointDeviation to show the current offset.
now move the CVs with
_moveUVN
start move them in N in steps that get smaller and smaller
0.5, 0.2, 0.1, 0.05, 0.02, 0.01, 0.005, 0.002, 0.001
if this is not a technical surface, and there will be a final 0.5 mm Radius - a precision of 0.01 will be more then enough.
the surface attached is a 5 min action.
patch_tp.3dm (4.2 MB)
Yeah exactly, there will be a fillet which it can cover the gap.
This case is kind of easy to do manually because of the flatness of C but I still wonder what could I do for other more complex shapes.
Nice fancy command, I learned something today.
Thanks!
