Move command too basic
Hi, wondered if move command could have options such as ,perp.to ( then pick line , or crv.) then it could follow a circle or arc without a lot of manual manipulation? I use 3d rotate some to do this .
Hi Martin - use object snaps for this, including OnCrv, Perp, Near, etc. Does that do anything you like?
In frt of the beast now. I will give it a try. Thank you
The osnap oncrv worked well . Thank you
