Most recent WIP deleting all objects in an existing project
Twice now had deleted all objects (leaving empty layers) after importing an .obj into the project in one instance and simply moving an existing (dragging) in the other… Lost a days work :frowning:
Hi -
Thanks, this is being worked on:
RH-90586 Rhino WIP Undo Crash
It is never a good idea to do commercial or otherwise critical work in a WIP version of a software.
didn’t say it was either of those, but it was still a lot of work.. and not really the point
@pharris65 Did you try going back to an earlier saved version of the file? If this a a day’s work there should be several versions of your file, I assume.
well, because of the size of the file and the issue on OSX (one of the reasons I keep annoying you guys re: Worksessions) with autosaving, I turned versioning off.. :frowning: - so yeah, I screwed myself, given this bug…
FWIW, with versioning turned off, saving a file will send an earlier version to the trash can.
RH-90586 is fixed in Rhino WIP
