Modify RMB context menu
It’s been a while since last time I used Rhino for Mac. Is there any way to modify the commands from the RMB, similar to the option we have in Rhino for Windows?. It would be great if I could add a few of my most used shortcuts to the RMB.
Cheers,
josé
Select Rhinoceros > Commands > Customize… Click the button in the upper left corner of the dialog and select Duplicate… to make a duplicate command set. Edit the Popup tool palette by dragging and dropping tool palette buttons into the center top panel.
