I use Rhino as 3rd party software for game development. I build my models on the horizontal plane, but when I export them to Unity or Blender, the models are rotated sideways. Is there a way to prevent this from happening?
Thanks
Check your export options. There is an option like map Rhino Z to Y, not every software has Z as up. If both software has Z as up then make sure that is off.
At first glance I thought it was a heat sink.
I see that now, though I’ve been working with FBX files and it has the same problem, with no similar settings in the export menu. Is there a way to map the Z and Y with an FBX?
Hi Aurora - this is from the Rhino 6 export dialog box:
Looks like you may have to manually rotate in that case (or maybe someone has a script)
A macro will work:
! _Select _Pause _Rotate3d w0 w1,0,0 -90 _Export _Pause _Undo
Ok, where would I enter the command?
Hello - you can copy/paste to the command line, make an alias, add the macro to a button - any of the normal ways to use a macro.
Awesome, thanks!
