Hello.
How to change rhino to 3ds max exporting settings to make files export with same rotation? Right now after exporting from rhino fbx format to 3ds max, model is rotated 90 degree in Y axis.
Hello.
Hi Raimondas - you can use a macro in Rhino:
! _Select _Pause _Rotate3d w0 w1,0,0 -90 _Export _Pause _Undo
But, exporting OBJ has an option built in to map Rhino Z to Y on export as well.
Ou! Thanks very much, you solved my problems! :))) Very good script.
