FBX Export.....Y?
Will it ever be possible to export the FBX files with the “Y” and “Z” axis reversed?
Thanks
Hi Brian- what you can do for now is to make a macro that rotates the objects, exports and then undoes the Rotate, e.g.
! _Select _Pause
_Rotate3d
w0,0,0 w1,0,0 -90
_Export
_Pause _Pause
_Undo
I think the macro above will not exchange Y and Z, it will make Y=>Z and Z=> -Y.
Exchanging of Y and Z is a mirror operation in the plane with origin (0,0,0) and normal (0,-1,1). I’m not sure how to set that in a similar macro though.
yeah, you’re right- it changes from ‘Z Up’ to ‘Y Up’ but does not really swap the two- sorry Brian… thanks menno.
try
! _Select _Pause
_Mirror _Copy=_No
_3Point
w0,0,0 w1,0,0 w0,1,1
_Export
_Pause _Pause
_Undo
Is that better?
Hmm, I might try it anyway. Thanks for the suggestion!
