i am sure i will have problems so maybe its nice to do the work in progress here
nice !
just some more pipe so i learn a lot and if you do it a lot you get it in your fingers
by the way i did the tween Curve command just for some practice i understand what it is now… but i really like to
know some example where you can use it for
greetings Peter
at the moment i have some small problems with the saddle the problem is i want to merge the surfaces togrther on a smooth way but ??? maybe somweone can put me in the right direction i think the result is not so bad but i think this is just luck i really do’n know what i have doe -
Really nice!
As a fellow ‘dutchman’ I can truly appreciate this ‘Oma Fiets’
-Willem
