If I try to upload my model to shapediver, i get the following error message:
Oops! The server encountered an issue with your model: Computation of your model failed. Please ask for help on the forum, including the reference shown below in your message. (Ref: 750e9733-46ee-49f4-a207-1d19560021c4)
I checked, that all packages used are compatible, maybe it is because of the big voronoi pattern?
Please find attached the file I am trying to upload.
The problem with your model is that it has a very big mesh in a single ShapeDiverDisplay component. You have a single mesh that has almost 200k faces so the solution is to lower down the mesh below 65k vertices or to output the different parts of your mesh (So do not join the meshes before the ShapeDiverDisplay component) in different ShapeDiverDisplay components.
Thank you for your quick reply. I tried your inputs:
Deleted the join-mesh component - No Luck.
Instead of joining the meshes in one mesh component, several different meshes into the “ShapediverExport” - No Luck
Not including the voronoi mesh at all - No Luck.
I need all the parts to be exported in one stl file, to be able to print it afterwards.
Hi @gobatgobat, I have found the main problem with your model. You are using a font that is not in our servers (ProximaNova). To look for fonts that are stored in our servers you can use our Font Browser.
