Shapediver computation model failed Ref: 2ae90054-6584-4890-b1d3-9e1f60d18587
Hi guys, i have some issue after upload on website, the upload is ok but when i click on publish, after some seconds, appera this :
Oops! The server encountered an issue with your model:
Computation of your model failed. Please ask for help on the forum, including the reference shown below in your message.
(Ref: 2ae90054-6584-4890-b1d3-9e1f60d18587)
many thanks for ther help
Francesco
Our logs show that the initial model checking failed because of the size of the meshes to be displayed. This problem should be reported back to you instead of the generic error you saw, we will work on fixing this issue.
In order to make this work please work on radically lowering the amount of vertices and faces of the meshes your model is generating. In case you are meshing surfaces or breps, try to use custom meshing settings and tweak the parameters.
