Your model contains around 70 script components, which needed to be manually confirmed. This is now done so you can try again. However, keep in mind that you should try to limit the number of scripts. Scripts need to be compiled on the servers before running, which is generally fine for a handful of them but starts taking its toll when there are… 70.
I understand there is a problem with upload file… But my model is so complex… so I cant understand where is the problem…
For example if error message can show me how many mb my model is problem I can understand where is the problem with trying changing model parameters etc…
so how can I see what is my model upload mb?
cause my model is 7 MB but error message is for 20 mb
If I understand correctly, you are now referring to a different problem which you already reported in a different topic, and for which I just provided an answer. See the discussion there:
