23_07_23_website bench_vs7.gh (17.9 KB)
Can someone please help me, I do not understand why this model keeps on failing
@thys if you mesh your output and give it custom settings, the model becomes way faster. This is the file with the small change:
23_07_23_website bench_vs7.gh (28.3 KB)
If you want to know the reason why this happens, you can read our blog post Meshes vs B-Reps Explained
Hope this helps!
Thank you so much, I wish I posted it earlier.
Just a follow-up to this topic, because while Edwin’s solution made the model faster, it still shouldn’t have timed out to begin with.
As it turns out, the problem was elsewhere: in your initial model, you have a text panel with an exotic font (Futura Light). If you try to open this model on a system that does not know the font, you get an error pop-up and a prompt to replace it with a fallback. This is the real reason why your model timed out, because our servers did not know how to handle this case.
The problem will be fixed in the near future, but in the meantime make sure to stick with standard fonts in order to avoid this issue (I believe the default one is Courier New).
thank you, i will make sure to watch out for this.
