Has anyone else experienced issues printing a PDF with mixed vector/raster in the layout after the latest RH6 update? I’ve been printing a particular file just fine, now it crashes as it’s saving the PDF. I tried using a couple different PDF writers and re-inserting the images with no results. The same file prints fine without the image.
Hi David, I don’t think that crash report is the one since this problem started yesterday after i downloaded the update. Let me check with work and see if I can send overt the file. I’ll get back to you shortly
Instead of uploading the original file I just made a test file using an image with line work and it also crashed when trying to print a PDF. I attached the file and image.
log still says:
%%[ Error: syntaxerror; OffendingCommand: --nostringval-- ]%%
Stack:
/definecolorrendering
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
I’m not able to reproduce the crash using the same Rhino version. I would recommend you update your GPU drivers since they’re 1.5 years old. Let me know if that solves your problem.
So I reintsalled the drivers and windows device manager shows the correct driver but Rhino System Information is still showing the outdated driver. Not sure if this has to do with the problem I’m having. See below.
I did a complete uninstall using Revo then reinstalled the drivers. It did show up as current in my Rhino System information but unfortunately it didn’t fix the issue
I was trying to print some AO shader with an Acad imported plan on top. Was using a Surface Book with Nvidia Gpu at that time.
Tried with Rhino PDF, Adobe Pdf and Microsoft print to PDF drivers.
the thing which was a bit shocking was that the when using Adobe pdf the entire Computer locked up.
Meaning I could not even restart… Task manager showing 100% CPU on “system interrupt”
Had to hard shut down via Power button a couple of times!
When using Rhino PDF small resolutions would sometimes work bur higher res came out as a blank PDF.
Which oddly still had a filesize of 500kb or so.
