Rhino crashes when printing vectorized PDF
Hello everyone,
My R8 crashes immediately when printing PDFs. As soon as I switch to vector output in the print options, the program crashes, regardless of the printer (adobePDF, rhinoPDF…).
For now I’ve been printing rasterized, but it is really inconvenient to have this output long term.
It would be nice to have at least the things from the layout vectorized.
I have a workflow with blocks, custom viewing modes and clipping sections, including respective section styles.
I usually print by layout sheet. The 3d geometry in the layout detail is cut by plane, with repective section style, instead of 2d linework, so I assume it’s not the easiest thing thing to handle for rhino…
Please, if someone has found a solution for this…
Stats:
Rhino 8 SR10 2024-8-15 (Rhino 8, 8.10.24228.13001, Git hash:master @ f4c93f2b85de4dc69b50ed22f1b0d91445724d03)
License type: Educational, build 2024-08-15
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 40GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24228.13001
A couple things we can troubleshoot.
Let’s start by disabling the 3rd Party plugins (Vray) via File>Properties>Plugins
This will require a restart of Rhino.
The next thing to try is to disable GPU Tessellation in File>Properties>View>OpenGL , restart Rhino.
I do see a crash report that we can analyze today.
Thanks first of all!
sooo:
it does work for two view modes now: “monochrome” and “pen” print vectorized linework, but you don’t get any of the shaded textures, effects and shadows.
As soon as I switch back to rasterized, the effects appear again.
The other viewmodes still print rasterized layout details. Titleblocks on layout sheets stay vectorized.
Any idea how to circumvent this?
kr.
gabriel
What did you change so far?
I disabled 3rd party plugins and the tesselation on the OpenGL.
In general no crashes anymore, which is great.
Now stays the issue with rasterized images with most viewmodes.
If you disable the clipping planes in the views does the rasterized work for you?
If you can’t post the model here you can upload privately here, please put a link to this thread in the comments
turned on and off the clipping plane. Nothing changed. When I’m on vector mode, all shading and effects dissapear on detail, except for the vectorized linework. Is this a feature?
Just uploaded the model to tech.
This issue should be fixed in the Service Release candidate.
You can change your Update frequency to Release Candidate and check for updates:
Thanks,
Mary Ann Fugier
Hello Mary Ann,
Any idea when this will be released?
N
Hi @nsgma,
You should see sr11 become the public release by midweek, if nothing unexpected nothing holds it up.
You can get it now as the release candidate.
It would be best to know sooner rather than later is if it is fixed for you be testing with the release candidate.
Can you do that according to the instructions above?
Thanks,
Mary Ann Fugier.
Hello @mary
Sorry I only had time to check this today. I have the most recent SRC
The problem persists.
N
@nsgma could you share a file that causes this crash? If we can repeat it, we will get it fixed right away
Hi @nsgma,
I looked at the one crash dump you submitted - thanks for doing that. The report shows this:
Plug-ins:
  • AMDDenoiser.Windows (0.5.3.0)
  • Lands Design (6.1.1.9957)
  • NVIDIADenoiser.Windows (0.4.3.0)
  • SectionTools (Aug 13 2024 06:17:59)
  • Tibidabo (21.2.2.19205)
Can you disable these and see if the crash does away. From Rhino, select Tools > Options > Plug-in and sort on “Plug-ins that do not ship with Rhino”. Uncheck the box next to them and restart Rhino.
Also, can you run Rhino’s SystemInfo command and post the output?
Thanks,
– Dale
Hello Dale
After turning off the plug ins the problem persists.
N
Hi Dale,
I have identified that the issue occurs with a Detail in Technical display mode. It seems to have to do with the print menu preview.
When I change the technical displaymode to Wireframe, the preview appears and they the PDF is produced.
I tested also the Monochrome display mode and it similarly crashes.
N
HI @nsgma - can you run SystemInfo and point the results in a reply?
– Dale
Hi @dale
I still have this problem. any progress on this?
N
Hi Nuno -
Dale asked you twice for your SystemInfo command without a reply from you…
Other than that, I’m not seeing any recent crash reports from you. Please always send those in.
Hi @nsgma,
You never never answered my question…
– Dale
Hi, I am experiencing a similar problem. I can’t plot with Vectors if I have overriden at least one of my objects with a different display mode (using SetObjectDisplayMode or via Properties Display Mode… Multiple Viewports) and the result I get using Raster is not satisfactory for my drawings. Apparently disabling one of my plugins -VisualArq- solves the problem, but unfortunately that doesnt solve the problem because I am using the plugin to generate this view… Are there any other options? How should I proceed? thank you!
