Hi there,
i am trying to build a minimal surface, like a membrane that fits through the three round holes ant the framing curve (base). i have tried a lot of commands (patch, loft, etc.) but i was not satisfied with the result.
Then i added the short curves from the hole to the framing curve and tried the surface > curve network command and the result is better, but there are this two edges that are going from the hole to the round edges of the framing curve (you can see the isocurves). Ireally want to create a soft membrane without edges in the surface. and it would be nice to solve this problem without the short curves, just using the three holes and the framing curve as reference. perhaps someone has a clue. Thanx for help!
Hello Pascal,
here is the model. New Version, I divided the surface in 4 parts and patched the 4 surfaces. them joined them into a polysurface. Still not really happy with the result. I would rather like to have one single surface. Dont know if its possible.
Thanx!BERGHAIN_Einzeln_160818.3dm (14.4 MB)
Hi Pascal,
the Image looks great, but i cannot open the file because we use rhino 5 in our university. Could you send it again so i can open it. Would be nice.
And: what you mean with it`s not a minimal surface? How did you build it? Want to learn : -)
Thanx a lot for your efforts…
Hey Major Tom: you seem to be a lucky boy who was born with infinite rhino skills ! a real pro! Well… i guess you should rather share your magic skills instead of telling people what they have to do or how to act. What goes around, comes around! KARMA my man!
