Hi McNeel
I’ve been seeing this quite a lot, but here’s finally an example I can share. When importing FBX files I often see parts that are weirdly offset from the actual model or in other ways jumbled. Shown here is the same FBX file imported in Rhino (bottom) and imported in Keyshot and then exported to Rhino via OBJ (top) - even though it’s a crappy lo-res model, the top one didn’t drop its sideboards and total the rims like the Rhino import. Is this something that can be tuned up?
BMWI-White-fbx.FBX (10.6 MB)
Thanks in advance, Jakob
Edit: I realize that FBX isn’t always the best interchange format and try my best to avoid it, but sometimes that’s just not possible. In his case, it’s clear that some objects are out of place, but sometimes it’s much harder to spot where/what went wrong.
