Hi McNeel
I’ve been meaning to write this up for years
When importing some FBX files (I don’t which FBX version, but some of these are probably 10+ years old), the individual objects in the files come in scattered all over the place. Here is a very simple example with only two objects: a chair and a small surface where the logo goes. And the logo surface doesn’t line up. If I import the same file directly into Keyshot, everything lines up. Can this be tuned up, or is the FBX import something you don’t make in-house?
Don’t worry. It has been written up years ago
→ RH-52783 FBX Import - objects are scattered
(there’s an older but private ticket as well… RH-49831)
[I guess let us know if you can make sense of the FBX spec…]
Hi @wim
Thanks - so at least it’s not a ghost in my machine Blender complains that the FBX version (in this case, at least) is 6100 - not that I’m any wiser
I’ll see if I can find a converter somewhere!
-Jakob
This was working for me:
Until Tim Hemmelman fixes the bug, a workaround is to open it in other 3D software (for example, RizomUV) and export it as OBJ. This will apply the original transformations. Import the OBJ into Rhino.
