Continuing the discussion from Make2D Scene Silhouette:
Hi @rajaa,
“Do you like the result to be in the 3D location? Do you only need it for ‘meshes’, or it can be any geometry type?”
1.As Meshoutline works on both Mesh and Nurbs currently, So it should keep the same capability.
2. 3D location should be at the same place because it can avoid scaling process in Adobe illustrator.
“I wonder if it would work better a a separate command and not part of Make2D?”
I think it should work like what you post in the discussion. I think just add another “create object outline.”
It is the same idea you demonstrated.
Here is the reason why
