Creating a simple outline drawing still produces multiple overlapping output curves of more complex geometry.
When using Make2d on a geometry set consisting of multiple unjoined surfaces, or polysurfaces, it’d be great if we could still produce a true outline drawing without internal surface edges and overlapping curves.
Sometimes, I have a model and don’t need/want to join the surfaces and then create a drawing.
Thanks. That’s what I thought would work but it draws all the surface edges. In this case the surfaces are not joined. In many cases I have a model consisting of many un-joined surfaces which I don’t need to join but still want to create an outline drawing of.
But on different layers, right? Here if I explode a box and Make2d, the scene sihouette is correct and the individual face curves are on a different layer
