Hi!
I’m new in Vray (trial) and trying to find out if I would like to move from Brazil to Vray…
I have problem with material scaling. Viewport changed to “rendered” works like I want when using repeat U/V (15), but rendering does not work… Why it does not scale?
Hi Wagner,
I can only recommend you to stay away from UV in V-Ray and rather set as much as possible directly in Rhino texture mapping tool. If you keep V-Ray texture Repeat UV at 1/1, your rendering will always match the viewport.
