If I setup a ClippingPlane for a Section, and then set up a custom Cplane that relates to the Clippingplane for the drawing, then project the Make2D to the CPlane, to keep the geometric references all inline, it often skips writing the ClippingPlaneIntersections layers. Occasionally creating a few random incomplete curves, just for kicks.
Is there anything I could be doing wrong about this? Or is it just a known issue?
It seems to be true in R6 and R7.
Sometimes I just have to use a custom parallel camera and the “View” option, and then reorient the results onto the manual CPlane.
I’ve tried the SectionTools plugin, but using it just to make up for the deficiencies of an already existing command is a little wonky.
I could provide screenshots if necessary.
