Hello, I have set everything (i think) up to create 2d of a section on rhino. I added the cutplane and can see the section i can see what its cutting and everything looks good. Yet when I type in make2d and select the object I’m not getting a 2d of the section cut, I am either getting an elevation or like 3 lines and not the actual shape. I feel like I have tried all the combinations for the make2d settings but am apparently missing something cause its not working (obviously). Clipping plane intersections is selected so what’s the issue?
Please give it a try with ClippingDrawings, Please note that the placement of the ClippingDrawing should be within the visible area of the current viewport’s ClippingSection.
@jessesn @rajaa I think there’s a need for an explicit disentangle/disassociate command here that severes the connection between a plane and a drawing.
