Make2D 6 primary views
How about adding an option for a 6 view setup viewing the 6 primary views?
Currently there is no simple option to run make 2D once with
right, front, left, back, top and bottom view…
a picture is worth more :
Do you think it might muddy the standard first angle and third angle projection? I think it may confuse people… There is a really long thread (which you may have been part of?) which discusses the use of a reflected ceiling plan for architects and designers.
I do think that would be a good option… Perhaps if the Make2D punted out an annotation dot in the corner of the projected view which tells you which view it is? Many people get confused between the US and EU standard which V6 has ironed out thankfully.
Andy
