Hi Debo,
Can you explain a bit more about what you’re getting? Is there also a sample 3dm file you can share to show the issue(s). I think you have some incomplete line work after Make2D but would need to file the sample model in a bug report to hopefully get it fixed. It could be something specific to the actual geometry that we aren’t handling correctly. You can email tech@mcneel.com to my attention as well if the model is confidential.
Maybe this could help?
Yes - it helps. Though, I had to rebuild with the new settings in place - the Make 2-D is faster too. Maybe I have to adjust my template with this lower tolerance - it’s enough for my kind of work. Thanks.
Thanks for showing what you found with tolerance adjustments. I added this info to the bug report filed too. I know development on Make2D continues and this feedback helps define what to work on.
Thank you Brian, I hope it will help:)
