I am dealing with a rather large project. (30 residences)
When I try to output 2D from linked models (worksessions), It works on the first model then crashes when update computes newly added models (same worksession).
See attached video!!
Any help would be greatly appreciated, including a proper way (workflow) to extract 2D from VisualArq.
Thanks for your files, I have been testing it and I could reproduce the crash, so I am reporting it to find a solution.
I think your first workflow is better because that way you are not creating extra 2D geometry as you are directly producing your documentation from the 3D model. My suggestion is creating the dimensions in a separate layer in the 3D model (not in the layout); this way you will have them available in every layout and they will not slowdown your workflow.
It is the same, you can create a layer for the plan dimensions and another one for the section dimensions. For example, here I created a layer called “DIMENSIONS” with two sublayer, one called “Ground floor” where I am creating the dimensions for the ground floor and another one called “Section S1” where I am creating the dimensions for that section so that I can choose which dimensions to display in each view.
I see snap to objects is not working in section if you are in perspective view (I’ll add this request to our list), but you can do it by aligning the view to section as shown in the following image. If you use the “Project object snaps” option you will make sure that you are creating the geometry in the active construction plane.
What do you mean by “section mode”? Is it this option I showed in the previous image? If that is the case, please, could you send me your file? I’ll test it to try figuring out why it is so slow.
We have already solved the crash you had working with worksessions. It is solved in the upcoming version, VisualARQ 2.13.2. I send it to you now, so that you can keep working:
