Loft not respecting selection order?
No matter what I do the loft is never doing what I want it to do and I have to do the loft in grasshopper.
And there is no way to change/edit the order.
Happening here again:
Hello- if you pre-select, the automatic sorter outer does the sorting - order of selection is not recorded - it can give you something other than what a human would think it reasonable. For full control, post select, in order. If that is what you are doing, then we need to dig some more.
Eventually, when I am king, you’ll be able to change the order, add and remove curves, on the fly but we are not there yet.
Okay so type Loft first, then select my curves. That works to create a custom order. Thank you Pascal.
Huh, all this time I thought it was. Funny.
Soon™
