Running RhinoWIP 5.2 on Mac El Capitan (10.11.3). Whenever I try to launch Grasshopper via the ExplicitHistory command the Parental Advisory window loads to 100% and then the window below pops up. Been trying for a few months since grasshopper first came out on WIP for mac. Tried on two different computers with the same results.
Curious if anyone else is seeing the same issue and if they’ve been able to solve it?
Excuse my ignorance. How do I attach a definition?
This is what came up in my command history:
Command: ExplicitHistory
An error occured during GHA assembly loading:
Path: /Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/GrasshopperPlugin.rhp/Components/GalapagosComponents.gha/GalapagosComponents.dll
Exception System.TypeLoadException:
Message: Could not load type ‘GalapagosComponents.GalapagosEditor’ from assembly ‘GalapagosComponents, Version=5.2.246.0, Culture=neutral, PublicKeyToken=null’.
edit:
Just a note as well I have not loaded any plugins into Rhino. I know Galapagos is a plugin so I am a bit confused on why this is popping up?
Ah, I see the source of confusion. I should have just said “Please upload the Grasshopper file/document that is causing this problem.” Grasshopper files/documents (.gh, ghx) are sometimes called “definitions”.
Wim is correct. I am hitting a wall before grasshopper loads.
I open a new rhino file, execute the ExplicitHistory command, the parental advisory modal loads to 100% and I see the scribble error window. The parental advisory modal stays present and will not go away until I quit rhino. I’v never been able to load the grasshopper interface.
Interesting. I misunderstood. Thanks for the clarification. I’m not seeing this here in 5C249w. Can anyone else reproduce this issue on their machines?
Rhino opens like usual. MacPlugIns folder only has IronPython when a new rhino file is created. After executing ExplicitHistory a Grasshopper folder is created and the same thing happens. Parental Advisory loads to 100%, Scribble error window pops up, no Grasshopper UI.
Since my command history mentions: "Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/GrasshopperPlugin.rhp/Components/GalapagosComponents.gha/"
I did mess with removing those files one at a time and in different combinations with no success.
Here is my command history again for reference:
Message: Could not load type ‘GalapagosComponents.GalapagosEditor’ from assembly ‘GalapagosComponents, Version=5.2.249.0, Culture=neutral, PublicKeyToken=null’.
Has anyone managed to fix this ‘GH_Scribble Levels 1, 2, and 3’ bug yet?
I really need Grasshopper to work on my Mac but am struggling with this bug…
I have downloaded the RhinoWIP_5D132w.dmg
I presume you mean this one (RH-36518)…? Also reported in this thread…assuming they are the same bug, but we can’t be certain. We are still unable to reproduce this one. Can you help provide steps to reliably reproduce it?
