I have a problem with loading Explicit History on Rhino WIP 5D92w (on iMac with MacOS Sierra 10.12). After 100% loading of components it stops with alert Grasshoppers Loading Errors: Object: GH_Scribble (level 1) …level 2 … level 3. This bug was reported couple of months ago by some other user (Loading Errors: GH_Scribble Levels 1, 2, and 3), however, any solution was recommended yet. Could you please help me somehow? Thanks.
Next step I would ask you to try would be to remove any other Grasshopper components you may have installed.
These are in: ~/Library/Application Support/McNeel/Rhinoceros/MacPlugins/Grasshopper/Libraries
and see what happens.
Thanks for quick reply. Alas, none of those solutions you mentioned didn’t solve the problem. I run MacOS Sierra 10.12 on my iMac but it didn’t work also on latest El Capitan 10.11.6 I used before. However, I just installed this Rhino WIP 5D92w on my Macbook Pro (with El Capitan 10.11.6) where I do not have full Rhino 5 installed yet and Explicit History works smoothly.
Unfortunately, right now, we can’t reproduce the issue, but we are tracking it. Logged in MR-2904. I wish I could give a workaround…it is likely configuration-specific (hardware or software), but we don’t see a pattern yet.
