Loadable families with subcategory
I’ve tried to create Loadable Family Component with new subcategory but I have still some problems with New Component Family.
When I’ve resolved problem with categoryId: 1. The input category id cannot be assigned as the new category for this family.Parameter name: categoryId.
I get the error 1. ElementId cannot be deleted.Parameter name: elementId
Why the error appear: which elementId cannot be deleted? I cannot understand what I do wrong?
Any help and advise appreciate.
New Component Family_rhino to revit.gh (14.4 KB)
Annotations triangle.rfa (304 KB)
Is the problem the Category <> SubCategory component that is plugged into the Main Family component?
Also, do Generic Annotations support Loadable families?
I will take a look.
Main Family Component you mean all Model categories (not Annotation) like for example Lines?
I’ve tried to use Model categories but I’ve faced problem with categoryId: 1. The input category id cannot be assigned as the new category for this family.Parameter name: categoryId.
I want to create family contains flat triangles with possiblity to assign angles and lenght of the sides of the triangle via shared parameters (please see picture above).
I thought the generic annotations template will be the best choice. If you have any advice of model categories and templates to create flat triangle (lines or surface) I really appreciate.
Normally if I wanted a family to adapt to the Grasshopper shape, I would use an adaptive Family.
Here is an example: Rhino.Inside®.Revit
Is this an existing Family in Revit which you are trying to change?
